Hi B_Lind,
Yes, the NI 9477 can be used as a relay contact. The MOSFET switch does not have a wetting current. Because it is solid-state, there is no oxidation layer to burn through like there is when you work with electromechanical relays.
Good luck with your application!
Jared R.
Precision DC Product Support Engineer
