11-05-2012 11:26 AM
I am using one output from the NI9476 module to give me a watchdog signal. Therefore it turns on and off every second. How long should i expect the output to last?
This isnt a problem if its a transistor rather than relay, but i cant find any reference to what type of outputs they are on the above module.
Solved! Go to Solution.
11-05-2012 12:56 PM
Where is the relay ?? ??
As far as I know the NI9476 has solid state outputs. So you should ask NI for the reliability figures.
But I think you computer will die before the output module does.
And normally a relay would last at least 1.000.000 switch actions or more. Within weeks the relay is worn out.
Kees
11-12-2012 03:17 AM - edited 11-12-2012 03:17 AM
Hi Kingo
Sorry for the late reply but I had to get this information from R&D. I can tell you that the NI 9467 has solid state switching in the form of transistors and no relays are used in it's manufacture.
Many Thanks
Dan
