Digital I/O
NI 9476 output module watchdog
I am using one output from the NI9476 module to give me a watchdog signal. Therefore it turns on and off every second. How long should i expect the output to last?
This isnt a problem if its a transistor rather than relay, but i cant find any reference to what type of outputs they are on the above module.
(5,477 Views)
Where is the relay ?? Smiley Surprised ??
As far as I know the NI9476 has solid state outputs. So you should ask NI for the reliability figures.
But I think you computer will die before the output module does.
And normally a relay would last at least 1.000.000 switch actions or more. Within weeks the relay is worn out.
Kees
(5,469 Views)
Accepted by kingokingo
Hi Kingo
Sorry for the late reply but I had to get this information from R&D. I can tell you that the NI 9467 has solid state switching in the form of transistors and no relays are used in it's manufacture.
Many Thanks
Dan
Daniel Harryman MEng
CLA, CPI
(5,429 Views)
