Digital I/O
NI-9472 to trigger a relay with 5V Output signal
Hi everyone,
I am trying to trigger an electromechanical relay with 5V Coil Voltage using Digital Output from NI-9472. The idea is to generate a single 5V pulse from LabVIEW that would trigger the relay once.
Can it be done through this DAQ card without the need of external 5V Power source? The current required needs to be 106 mA and I guess the 9472 can generate outputs up to 0.5A.
Some feedback on this and my scheme would be appreciated.
(1,172 Views)
Digital Output lines do not source any voltage on their own, you need to feed in external voltage as shown in the image
In your case, the "Device" is the 5V relay and you must connect a 5V supply to VSUP
Santhosh
Soliton Technologies
(1,144 Views)
Thanks Santhosh for your reply. Does this look correct now?
(1,130 Views)
Accepted by SS23
Correct!
I would guess that the SPDT switch is used to either allow control by cDAQ or through Push-button manually.
Santhosh
(1,115 Views)
