12-11-2014 10:05 AM - edited 12-11-2014 10:05 AM
Hi all,
I am using the NI 9401 module with the NI 9144 slave chassis and a third party master (Twincat). It seems to be that all 8 digital ports are configured as inputs. However for our project we also need outputs and I therefore want to reconfigure the module. I know this is possible using Labview. But because we are using a third party master, we can not use Labview to configure the FPGA. Is there another way to reconfigure the module in a way that we have four in- and four outputs?
Thanks for your help!
12-12-2014 05:03 AM
when the C module can be configured for input and output in the cseries module properties monitor in labview, it will also be possible to do this with other software. This monitor comes with LabVIEW but in another software you have to write the configuration on your own. Because the software is not from our company we cannot say something about the possible functions in that software.
http://ae.natinst.com/public.nsf/web/searchinternal/4828f9a252f081758625731e007d85f9?OpenDocument
Kind regards,
Dennis
