I am not able to operate any of my DO points on my 9375 except on the first run after reinstalling the cRIO software, after that it can't seem to find the DO points. All of the input points still work. I am using 2012SP1 and have updated the software on the cRIO, but that only seemed to work once after reinstallation and reboot. I get the following when the vi tries to write to any of the outputs.
Error -1950679035 occurred at Shared Variable in Untitled 1.vi
Possible reason(s):
LabVIEW: (Hex 0x8BBB0005) Unable to locate variable in the Shared Variable
Engine. Deployment of this variable may have failed or if the SVE is not
started.
This error or warning occurred while writing the following Shared Variable:
\\Powersupply\Mod4\DO2
\\10.14.34.180\Mod4\DO2
It is a problem when I can't actually control any real world outputs.
ryan.hampl@gmail.com
