Digital I/O
NI 9201+ 9474 troubles
i have an application that need's voltage measurements and a PWM input, i'm using a cRIO-9111 and the modules are the NI-9201 and the NI-9474 to do that.
I'm already capable of doing these to things but just one at each time, now i'm wondering to put them working together..i've already tried but it didn't work how i wish it did.
The acquisition was working to slow, it seems like i'm not having suficient points of my signal, to be honest i'd never understood the purpose of some waiting times inside of the wile loops and i decided to take them away and the response of the system becomes better but not enough.
If some one can help me understood the problem and how to regulate the acquisition to get a good signal view it would be great.
i'll attach the VI's i've used and a printscreen of what should be a 50Hz sine wave.
M_Silva
Message 1 of 11
(5,471 Views)
The problem you're seeing is not from your FPGA acquisition, but in the way you retrieve those values on the RT VI.
In your FPGA VI, as you said, you removed the timing functions in the Analog acquisition loop, so your module is acquiring datas as fast as he can (wich should be around 300 kHz or more).
Then, those values are updated on the indicator, and the last value is erased each time a new value appears.
But, in your RT VI, you have a loop wich reads theses indicators with a Read/Write control node, and this is in a loop timed with a ms function. From what's I've seen on your screenshot, it was timed around 40ms, so you display a value every 40 ms in your graph, that's why your signal is not as good as you expect.
You should change your timing for faster loop rate in order to get better signals, but a risk is to consume CPU usage and get an instable VI. So you need to be carefull and to verify that the timing you choose is not too small for the loop.
Otherwise, you can set a timing in your FPGA VI, wich assure a constant sample rate, and use DMA FIFO for getting the values accurately on the RT target. You can have a look in the example finder for Hardware Input and Output>>CompactRIO>>FPGA Fundamentals>>DMA>>DMA Buffered Acquisition - cRIO.lvproj
Olivier L. | Certified LabVIEW Developer
Message 2 of 11
(5,420 Views)
Hi Olivier,
thanks a lot for replying my message, the problem are already half solved...but unfortunatley every time i reach a solution for a specific problem i found a ten more problems to solve, that's what keep this interesting but hard at the same time.
I'm now using DMA to transfer and read data buti still not have the speed i wish, to reach the goal i need to creat a 20kHz PWM signal (i already have it working) and i need to view the PWM signal and the output of the IGBT's wich i am not capable to do at this time =(
Now i can't view a rigth acquisition up to 5kHz, when i rise my signal frequency i also need to rise the frequency of the acquisition loop rate and that leads me all the time to an overflow..i've read some posts that said to rise the number of samples read too, and when i try to do that the flg of overflow is still getting on or my signal seems to be stoped because of the Time to Acquire Block that is obtained by (1000/acquisition loop rate)* nº of samples...and that's what i'm think that slow's my acquisition, am i right?
Let me know if you have some sugestion...(i'll attach the code i'm using now)
Thanks for help, have a nice day.
Mário Silva
Message 3 of 11
(5,406 Views)
Hi Olivier,
Mário Silva
Message 4 of 11
(5,405 Views)
Hi Mario,
First, could you please give your complete project in a zip file instead of the different VIs. I could see some more details on target configuration and FIFO configuration.
Then, you have to verify several things doing this kind of tasks. First, your RT loop, as already said, can't run too fast because of CPU consumption, so you need to define a respectable loop rate. Then, you have to compare the RT Loop rate and your acquisition sample rate, in this way, you decide how much sample you need to read in your FIFO at a time. Then, you setup your FIFO size to be 2-3 times (at least) bigger than this number, and you should manage to acquire everything you need.
Message 5 of 11
(5,403 Views)
Hi Olivier,
thanks again for answering..i already this mornig start a new project, like the one that i've done yesterday, i am now capable of acquiring 10kHz PWM signal with a nice quality..
When you say "your RT loop" you mean my Host loop?? I thought i'm not using the Real Time yet, i always start a FPGA project..i'm i wrong?? How can i control my Host loop?? sorry if i'm asking you some stupid question but this kind of connection between FPGA, Host and RT mess me a bit..
I'll attach the project for you to see.
Thanks a lot
Mário Silva
