11-08-2006 09:27 PM
I am using a NI 6534 digital output board and Labview 8.0. I am updating 16 digital lines at a rate of 10kHz in a continuos update mode. For specific numbers of written samples a certain amount of samples get skipped at the end of the output.
To illustrate the problem I attached a vi. The total length of my output is approximately 3.1 seconds. This vi writes blocks of 1000 samples (corresponding to 100ms) to the output buffer until the buffer is filled to a certain level. After this the buffer gets refilled continuously to keep this level. At the end I write a final block of length L. If I choose L=200 or L=1000 everything is fine. But for example L=190 leads to 6 missing samples at the end of the digital output. The number of missing samples changes with L. To check this, the vi writes a pulse train as the final block. By monitoring this on an oscilloscope one can check that exactly 6 samples get skipped.
I would
really like to know what causes this problem and how to fix it!
Stephan
11-09-2006 03:45 PM
11-09-2006 06:15 PM
Hi Nicholas,
thanks for
your quick reply! I removed the waits as you suggested but unfortunately this
doesn’t change the odd behaviour.
In the
example program I monitor the number of samples written to the digital output
buffer in ‘TotalSampPerChannelWritten’. But this number is larger than ‘TotalSampPerChannelGenerated’
which the program reads from the corresponding property node.
Do you observe
the same behaviour on your computer? Is it possible that the problem is caused
by hardware/software that I am using? In addition to the NI 6534 I am running
two analog output boards (NI 6713) and a multifunction board (6070E) which are
all connected by a RTSI-bus cable.
Stephan
11-10-2006 08:12 AM
@stephanw wrote:I am using a NI 6534 digital output board and Labview 8.0. I am updating 16 digital lines at a rate of 10kHz in a continuos update mode. For specific numbers of written samples a certain amount of samples get skipped at the end of the output.
I would really like to know what causes this problem and how to fix it!
Stephan
11-13-2006 09:15 PM
Indeed, this explains my observation. Thanks for the help!
