Digital I/O
NI-6534 PCI physical pinout? can not find on datasheet.
I am having trouble finding the physical pin out of the NI-6534 PCI card SCSI connector.  I found the pinout on the datasheet, but it does not show how the pins actually correlate to the scsi connector on the card.  Does pin one start on the left or right side of the bottom (narrow side), or top (wide side) of the SCSI connector?
(3,875 Views)
Hi And-
A graphic showing the physical location and layout of the pins is available in this document.  Check out the Connecting Signals>>Making 68-Pin Signal Connections Section.
Hopefully this helps-
Tom W
(3,870 Views)
Thank You!
(3,861 Views)
