10-31-2008 05:27 PM
I have a PCIe-6259 board. I want to use input-output blocks in my .vi program (DIO Port Read, DIO Port Write, Read Digital Line), so I installed Traditional NI-DAQ (Legacy) Devices version 7.4.4. But, when I got to MAX (Measurements & Automation) and look on the left side under Devices and Interfaces I do not see the Tradional NI-DAQ tab; I only see NI-DAQ-mx Devices, PXI System, and Serial and Parallel.
Then when I go to run my program I get the error: Error-10401 occurred at DIO Port Config Possible reason(s): NI-DAQ LV: The specified device is not a National Instruments product, the driver does not support the device (for example, the driver was released before the device was supported), or the device has not been configured using the Measurement & Automation Explorer.
So, how do I get MAX to recognize that I installed Traditional NI-DAQ (Legacy) 7.4.4???
11-01-2008 10:26 AM
11-01-2008 03:49 PM
