04-28-2022 03:09 AM
Can anyone help , I need to send a digital output to the ni 9474DAQmx, I can get the unit to respond to the self test no problem. When I write to it does not respond. I have tried DAQmx native and DAQ assistant but to no avail. Here is one such attempt, with the wile loop greatly simplified.
04-28-2022 03:18 AM
Sorry see attachment didn't stick!
04-28-2022 03:22 AM
still didn't
04-28-2022 05:55 AM
1. Try using the "Test Panel" for your device in MAX
2. Try using a simple shipping example for digital output
Both are "known good" ways to produce digital output. Then, once you confirm that your device can work, come back to your code.
Do you get an error at 'error out'? What is it?
Try doing these two things:
- designate digital lines as well as the port, "cDAQ1Mod1/port0/line0:7"
- when configuring the DO task, wire up the 'line grouping' input to designate one channel for each line. I think the unwired default is one channel for all lines, which will be incompatible with the N channel 1 Sample write.
-Kevin P
04-29-2022 09:23 PM
Hi Kevin,
Thanks for the reply, this is my second reply to you as NI lost the first one in the ether.
I had tried the test panels and the device works fine.
I had tried finding examples but to no avail.
I had tried splitting the port by writing discrete lines both in DAQMX and assistant.
I don't get any errors when I split the port.
I suspect a mismatch between how I configure the device and what I am sending to it.
Thanks anyway.
