Wow, I have no idea how that previous post showed up. Some odd combination of accidental keystrokes, I guess.
Anyway, as I was saying, the 6528 is a superset of the 6527 functionality, plus it supports a higher isolation voltage, watchdog timers, and RTSI. The only difference is that it is programmed using DAQmx. There are examples that should get your desired behavior though. One other thing I forgot to mention, "Change Notification" from traditional DAQ is equivalent to DAQmx "Change Detection". I'd suggest looking at the DAQmx "Read Dig Chan-Change Detection.vi" as well as the "Write Dig Chan.vi" examples which when combined, should get your desired behavior.
I hope this helps!
gus....
