Digital I/O
Input from physical buttons triggering events in program
I'm trying to use the input from digital signals generated by a physical button to trigger events/functions in the code I'm working on. I'm building a unit that will have buttons that will send input via the digital I/O lines of an SCB-68. I can read in the values of the lines, but I don't know how to have (for example) the line going high trigger an event in the program. Would it be best to have functions reading the lines running in different threads? I found an example in the CVI 8.5 help dealing with change detection events but wasn't able to make sense of it.
Thanks!
(5,160 Views)
Which language are you using?  In LabVIEW, I would tell you to use a shift register to hold the previous value and look for a change in state.  On the change, I would use a queue or user event to trigger an action.
(5,159 Views)
Using C and LabWindows.
(5,154 Views)
If you want to avoid polling, you will need to use the change detection event:
http://digital.ni.com/public.nsf/allkb/DF5719473800838086256F1E0054FD7B
I would image you would read a port at a time then in your event call back, see which bit has changed and call the appropriate function.
Maybe if you had some specific questions about the example I could help you further?
Otherwise, you would need a separate thread, reading the digital values and checking for a change. If a change occurs then call your function.
There should be plenty of DAQmx examples to help with reading digital data.
I hope this helps.
Nick
(5,135 Views)
