11-11-2009 02:56 PM
Hi, Tom
Please ignore the above question. I used your jpg file to build vi.
One question is
For load data part, data is in boolean array. If I'd need to write several registers in different addresses of sensor, what's the convenient way of doing it? I was thinking of putting them into a txt file and read it but couldn't find the right vi to convert data (like 100100010100) into boolean array.
Or shall I use loop to read charactor one by one since they are just binary? Thanks for your suggestion.
Steve
03-08-2010 02:05 PM
Hi Stefo
I'm trying to use your code to do a 9-bit transfer instead of an 8 bit. Do you know how I could go about doing that?
Matt
05-07-2010 02:35 PM
Tom,
Would it be possible to use the PXI-6254 or the PCI-6035E to implement a PCI interface similar the the PCI interface that you implemented with the 6508?
05-10-2010 01:24 AM
Hi Dig3,
In general this kind of SPI communication is possible to implement with whichever board which has DIO and uses DAQmx - if you want to get faster transfer (HW timed), you can use 6254 board (it has HW timed DIO). If you choose to go for 6035E, you can only use speeds allowed by software timing of DIO.
Stefo
03-07-2016 01:32 AM
HI,ILLGG
I want to control the digital potentiometer AD5290 programming labview via DAQ USB-6009. I found Tom's "6508SPIemulation[8.0]_MOD2.vi". Unfortunately, I don't achieve the communication by using the VI. Could you post your successful VI sharing with me? Thanks a lot!
Bo Li
10-24-2017 08:26 PM
Hello Tim,
I was seeing your post on SPI communication with PXIe instruments.
I have a doubt regarding SPI clock duty cycle generation, can we modify
the SPI clock duty cycle according to our wish. If it can be done, where
should it be modified.
Thanks in advance..
