‎02-01-2024 07:17 AM
I need to generate 5V TTL signal for my board.
Can anyone suggest which NI card I can use to generate this signal.
I guess NI-7868R or 7854R can generate up to 3.3V TTL signal, please confirm this.
‎02-01-2024 07:35 AM
You can always add a logic level translator.
‎02-01-2024 08:13 AM
What other details are associated with this signal? Is it a "static" signal? Is it a clock? If so, what frequency? Is it a communication signal? If so, what data rate?
‎03-18-2024 05:23 PM
What EXACTLY do you mean by "5V TTL"?
Do you mean +5V is logic high?
Or do you really mean 1966 vintage 74 series TTL? "A TTL input signal is defined as "low" when between 0 V and 0.8 V with respect to the ground terminal, and "high" when between 2 V and VCC (5 V)" (Wikipedia).
