Digital I/O
I need help with digital output NI-DAQmx
Hello, I need some help to write in a digital output.
I've an array datos[5], and a I've create a digital output like as:
DAQmxCreateDOChan(task,"Dev1/port0/line0:4","",DAQmx_Val_ChanForAllLines);
Then I start the task(what I created previusly):
DAQmxStartTask(task);
And then I write:
DAQmxWriteDigitalLines(task,1,1,10,DAQmx_Val_GroupByChannel,datos,0,NULL);
But all of that doesn't work.
What I want to do is if I have an array "datos" who values are "0,0,1,0,1",
the first 0 writes in the line0, the second 0 in the line1,...,the last 1 in the line4.
I'm programming in C language, and I've seen the Refence C of NI-DAQmx.
How I can to do this?
(4,263 Views)
Hello Haiza,
You have written correctly the sequence of instructions, so it must works. The only thing is strange for me is that you have specified 0 instead on NULL or a var reference, the seventh parameter of DAQmxWriteDigitalLines.
I attach an example from NI-DAQmx driver. Compare with your code and look for your mistake.
Good luck.
(4,187 Views)
First of all I wanted to thank your quick answer, and tell you what I had a NULL value but I changed to 0. I'll change it again xD
I've a problem with the hardware, When I have arranged,  I'll try the code
(4,182 Views)
Hello, Sendia!!
I still have the problem with de DO and de Analog Inputs.
The digital writes works perfect, but when I go to read the analog inputs doesn't works.
The problem is that AnalogInput always print 0.000 when it shouldn't be because the sensor value is 2.3 (for example)
My code:
MAIN:
    TaskHandle task;
    DAQmxCreateTask("",&task);
    DAQmxCreateDIChan(task,"Dev1/port0/line0:4","",DAQmx_Val_ChanForAllLines); //To check the digital writes
    DAQmxTaskControl(task,DAQmx_Val_Task_Verify);
    for(i=0;i<3;i++) //This is to choose between the multiplexors
        for(j=0;j<8;j++)//to choose the sensors. Each multiplexor has a 8 sensors
            error = salida_digital(task,i,j);
            if(error==0)
                 entrada_analogica(taskAnalog,i,j); //In this function I've used readAnalog
//ENTRADA_ANALOGICA
    DAQmxReadAnalogScalarF64(task,10.0,&valor,NULL);
    printf("%.3f\n",valor);
(4,110 Views)
