I am using PXI 6508 for acquiring Digital Signals in my application. The Default power up state of the card while shipped is HIGH. Then I changed the Jumper W1 on the card to LOW and restart PXI. After this also the power up state of the card is HIGH. I used DMM to measure the voltage across the Port 9 and DGND. (pin numbers 98 and 100). I tried this for 3 ports and the result is same.
Please try using the Measurement & Automation Explorer Test Panel to verify the power-up state. If you manually pull low the lines low, what kind of readings do you get in MAX?
I connected the Jumper as per the picture and Measured the Power Up state. At that time alll the ports are reading HIGH. If I give a LOW signal manually to a particular port, MAX reads it as LOW signal.
