The first order of buisness is getting the image itself into LabWindows. We do not have a direct solution for this, but if you look through the developer zone you will find a number of people with
Keywords Search: usb camera. Generally this would involve making some calls to 3rd party drivers, which may be activeX based.
Once the image is aquired you will be interested in doing pattern matching over a series of images and using the change in the search results to track the object. You may want to use Vision Builder to help you develope the patern matching portion of the program.
Hope this gets you pointed in the right direction.
NI Applica
tions Engineer
Message Edited by Molly K on 02-19-2005 12:10 AM
