02-22-2006 12:29 AM
02-22-2006 05:22 PM
I strongly recommend that you upgrade to a newer version of LabVIEW. This will enable you to use the DAQmx driver, which will make programming your application significantly easier.
With that being said, the best way to control an LED is to use a digital output program. There are some great examples in the LabVIEW Example Finder for this. They will be under Help >> Find Examples >> Hardware Input and Output >> Traditional DAQ. Also here are the links to some other resources which should help you create this application:
Light Emitting Diodes (LEDs)
How Can I Interface My Digital Lines to an LED or a Switch?
Hal L.
