Digital I/O
How to set tristate logic using NI-DAQ 6212 in C#
Hi everyone,
I am very new to NI & seeking guidance from all of you, experts out there.
As the subject says it, I am trying to set digital output channel to tristate using DAQmx & C#. I found link on Tristate property, but I do not know how to use it. http://zone.ni.com/reference/en-XX/help/370473H-01/mstudiowebhelp/html/bd33b0d/
Any help would be very much appreciated!
Thank you.
(4,720 Views)
Accepted by topic author kasrus
Hi kasrus,
You would set the property using the following syntax (after creating your task):
digitalWriteTask.DOChannels.All.Tristate = true;
As the help document indicates: "You must commit the task for this setting to take effect."  The help document also highlights when to set the property in relation to a read or write.
This is referring to the DAQmx Task State Model:
Task State Model
http://zone.ni.com/reference/en-XX/help/370466AC-01/mxcncpts/taskstatemodel/
The configuration methods will move your task through this state model, but you can also control them using the syntax in the below article:
Verifying, Committing, Starting, and Stopping NI-DAQmx Tasks Programmatically
http://zone.ni.com/reference/en-XX/help/370473H-01/mstudiowebhelp/html/verifycommitstartstopdaqtask/
Kyle S.
http://www.ni.com/support
(4,707 Views)
