Digital I/O
How to export a clock in PCI 6534
I have a very simple question.
I am using PCI 6534 and I would like to export the sample clock to an output pin.  The code is as following:
    DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
    DAQmxErrChk (DAQmxCreateDOChan(taskHandle,"Dev4/port0/line0:7","",DAQmx_Val_ChanPerLine));
    DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle, NULL,1000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
    DAQmxErrChk (DAQmxExportSignal(taskHandle, DAQmx_Val_SampleClock, "/Dev4/pfi2"));
In the last line, I exported the sample clock to pin pfi2.  But when I hooked up an oscilloscope to pfi2 (pin 2 on PCI 6534) I observed no clock signal.  All I saw was a signal at ground voltage level.  What's wrong?
-Andrew
(4,199 Views)
There is a clock edge for every sample generated.  When you start the task, the clock should start pulsing.
(4,188 Views)
But ... that's exactly what I did and I didn't get any signal.
-Andrew
(4,184 Views)
Hello Andrew,
Do you see the same behavior if you export the sample clock to /Dev4/PFI6?
Micaela N
(4,178 Views)
