Tom,
An easy way to control the output rate for digital generation is to use the DAQmx Timing.vi. Place this VI anywhere between the configure and start VIs to apply a sample clock, for which you can define the rate. A good example of this is the "Write Dig Chan-Int Clk-Dig Start.vi". If you launch the NI Example finder (Help >> Find Examples), that example is located under Hardware Input and Output >> DAQmx >> Digital Generation. This example uses a digital trigger, which is probably not necessary for your application, but also shows the DAQmx Timing.vi in action.
Andy F.
