Digital I/O
How to connect the NI instrument (PXIe-6571) in Digital pattern editor ?
I am new to this and have just acquired a PXIe-5671. I have tried various methods while testing examples, but have been unable to connect to the 5671 in the Digital Pattern Editor. I'm not sure what the issue is. Thank you.
(443 Views)
I would recommend you taking up this course before even attempt to use 6571 - https://learn.ni.com/learning-paths/device-testing-with-digital-pattern-instruments
The error you're seeing from the example is because you don't the instruments with the names defined in the PinMap.
Santhosh
Soliton Technologies
(429 Views)
