07-11-2011 01:01 AM
sorry but I cannot open the attachment with the circuit diagram, I cannot open docx-files. Could you please attach a common file format, you attached a doc-file in another posting.
07-11-2011 04:35 AM
I hope this attachment can be opened.
Sufre
07-11-2011 04:57 AM
sorry but this attachment does not work either, I tried to open it with Word but it does not show up correctly.
Anyhow, you should check the voltage on the digital input with the LDR under light and in darkness (covered). The voltage for a high input should be above 2.8V and the voltage for a low input shcould be less than 0.8V.
07-11-2011 07:55 AM
I am sending a pdf file now, hope it works.
Kind regards
Sufre
07-13-2011 03:24 AM
OK now I can see your attachment.
At first glance there is nothing wrong with your setup.
What happens when you short (connect) the two output terminals? Since you (hopefully) use an open collector configuration this will just simulate an activated output transistor.
07-25-2011 08:36 PM
Wow, this is a great site. I mean yep, I also had the same problem in connecting the light sensor.
Gee, thanks for this great information. 🙂
07-26-2011 04:22 AM
Hi, Thanks a lot for your effort, its true there is nothing wrong with the circuit, it's just how the connection between the transistor output to the digital input.
Kind regards
sufre
