Digital I/O
How the hysteresis affects DIO input voltage levels of PCI-6602?
The PCI-6602 digital I/O lines have the following specifications:
_________________________________________
Hysteresis ............................................... 300 mV Schmitt triggers
Digital logic levels:
         Level                         Min             Max
Input low voltage         –0.3 V            0.8 V
Input high voltage          2.0 V      Supply +0.3 V
_______________________________________________
How the 300mV hysteresis affects the maximum LOW voltage of 0.8V and the minimum HIGH voltage of 2.0V?
Alternatively, where the hysteresis threshold voltages are located?
Thanks.
(3,133 Views)
Accepted by topic author Eyal
Eyal,
My understanding is that from a logic high the Schmitt trigger will keep the signal high until the signal dips below at least 1.7 and above 1.1 for the corresponding .8V low logic level.  So by that the thresholds would be located at both .8 and 2.0.
Sincerely,
Jason Daming
Applications Engineer
http://www.ni.com/support
(3,119 Views)
