01-28-2011 11:25 AM
I have a cDAQ-9178. I would like to use the PFI0 port as a digital edge trigger but I can't get it to work. I've tried dozens of combinations of export and connect terms to try to map the device route shown in the device monitor. When I try to set the trigger it complains there is no device assoc with the task.
I am using ANSI C.
Thank you,
Michael
01-31-2011 11:20 AM
Hi Michael,
Which DIO card are you using in your setup? There is a default port that the PFI0 exports on to. For example on the NI-9401, the default line that PFI0 is connected to is pin 14. You can find the routing information by right-clicking on the device in Measurement & Automation Explorer and selecting Device Pinouts. If you are still having issues please post your hardware setup and the code you have written so we can troubleshoot further.
01-31-2011 03:37 PM
Hi Steven,
Thank you for your reply. To elaborate on the question, the cDAQ-9178 has 2 BNCs on the chassis labeled PFI 0 and PFI 1. According to the manual I should be able to assign PFI 0 as a trigger input. The manual does not say that we need a digital input module to access the PFI 0 line on the chassis. For a visual of what I'm talking about I have attached an image of the User Manual showing PFI 0 BNC Connector (Figure 1 Item 2). How do I set the device route on BNC Connector TRIG0 (PFI 0) using Ansi C?
01-31-2011 04:32 PM
Hi Michael,
It should be something like this
DAQmxCfgDigEdgeStartTrig (taskHandle, "/cDAQ1/PFI0", DAQmx_Val_Rising);
Where cDAQ1 is the name of your chassis, and PFI0 could be swapped with PFI1 if desired.
Best Regards,
