Digital I/O
How do I output a hexadecimal string to equipment using the Visa Write function?
If I input a hexadecimal string to a Visa Write function, it gets converted to ASCII before it is output to the device. I need to send a hexadecimal string to a piece of equipment. The online help suggests using the type cast function, but this function requires two separate inputs, and I only have one.
(3,737 Views)
You will probably find that your answer will be answered more quickly if you post your question to the Instrument Control newsgroups. Another option is to ask your question in the LabVIEW or CVI newsgroup depending on your software environment.
Erin
(3,737 Views)
