05-05-2015 08:32 AM
Hi!
I'm using a PCI-6229 to send digital outputs to a power source and I need to send n different numbers in binary code. I need this to be periodic so I've used a while structure and the diferent numbers as the different components of an array. In this way the while loop writes the "task" repetedly at the period I have set to the loop using "wait until next ms multiple". So, it does what I want. The problem is that I need the loop to work at a higher rate than ms. It would be great if I could make it go at 0.01 ms. I have tried and even when the "wait until next ms multiple" doesn't like doubles it tries to work at this rate but the signal is not 100% periodic and I need it to be much more precise.
Does anyone have an idea to solve my problem?
Thanks a lot,
Júlia
05-05-2015 08:56 AM
05-05-2015 08:59 AM
Thanks for the answer!
Excuse me, could you please explain me a little bit more the solution you suggest?
I would be very pleased!
05-05-2015 09:14 AM
05-13-2015 11:15 AM
OK, thanks a lot for the answer. I've been looking at all the examples but I haven't found the precise one. I have been trying to use them but I don't know what do I have to connect , I have no idea about timing... Could anyone help me find an example of high frequency (100kHz) digital output generation? My device is a PCI-6229 controlled through SCB-68.
Thanks a lot,
Júlia
05-13-2015 11:50 AM
I think the example you want to look at is Digital - Continuous Output.vi. You can just use the onboard clock and set the sample rate to whatever you need (100kHz it looks like).
05-22-2015 09:40 AM
Ohhhhh!!!! Thanks!
That example was exactly what I needed. Now I need to do the same but with to channels... I mean, I need to send two different patterns simultaneously. What do you recommend? Using 2D U32 in write DAQ.vi or... Labview doesn't like it when I use twice the DaQ timing (sample clock).vi... it says ''The specified resource is reserved. The operation could not be completed as specified.'' What is the best solution?
05-22-2015 12:05 PM
You need to create a task that handles both channels. Then you can use the Multiple Channels, Multiple Samples version of the DAQmx Write.
05-25-2015 06:03 AM
Thanks to all of you! My project is now working properly!
