Digital I/O
How Can I convert hex data to serial binary and send through HSDIO 6551 channel with clock
Hi ,
  I am Kind of new bee to labview and HSDIO. In one of application my IC got configured by serial data from another device in system.
I need to replicate the same set of serial configuration data using HSDIO(6551) digital lines.
I have a stream of data in HEX formatlike FF 6A 01.... I need to send these data serially through single DIO channel like 11111111  011010101 00000001 with the clock on each bit.
could anyone helpme to figure out?
Any help will be greatly helpful
thanks in advance
Shan
(4,315 Views)
I would recommend you to refer the link given. It will take you to a knowledge base that discusses on the different reference designs available for Serial Protocol communication using HSDIO. The article also gives you links to download some typical examples which should help you build the your application.
Trust this piece of information is helpful to you.
Sagar G Yadav | Application Engineer | National Instruments
http://zone.ni.com/devzone/cda/epd/p/id/6200#0requirements
(4,287 Views)
