07-06-2017 11:34 AM
Hey everyone,
I'm using a LMT01 temperature sensor, I need to count the number of pulses in 100ms in a pulse train, each pulse is 5us on and then 5us off (square wave) i need the total number in 100ms to post process into a temperature. I'm having issues with counting the pulses.
But currently i am only picking up the start of each pulse train (the timer is at 5 seconds so i could work out if this was the case.). I am using the FPGA of the Myrio.
Has anyone had experience with the LMT01 LPG - Data sheet
Kindest Regards,
Aaron Page
07-07-2017 02:05 AM
Hello there!
This page might be of interest of you:
http://forums.ni.com/t5/Example-Program-Drafts/FPGA-Counter-and-Digital-Edge-Detector/ta-p/3519082
If this does not help could you please post your code so we can see how you tried to do it?
Best regards
/Gustav
07-07-2017 11:46 AM
Thanks for the link,
I have used a similar approach using a select rather than case, i have since initially posting this managed to understand how to work the FPGA. The code attached counts all the pulses. However there are several things i need to do which i am completely lost over.
I need to take the count number after 100ms or after so long of no new pulses and put it into a formula. (that is to say the number of pulses in the pulse train)
I need to reset the count (either after 100ms or 5 or so ms of no pulses if this is possible).
Any help would be really appreciated because i cant find anything on how to use the count number or take a value from the count at a certain time.
Kindest Regards,
Aaron Page
08-08-2017 08:09 AM
Hello again
Sry for the late response but I've been away for a while.. I found another forum thread, link below, in which it seems you got your answer?
http://forums.ni.com/t5/LabVIEW/Pulse-counting-in-a-timed-loop/m-p/3650129#M1025159
If so perhaps you could link or share the info from that one and mark it as solved just so others with similar problems could find their answer there?
Thanks!
Best regards
