01-28-2019 03:01 AM
Hi Everyone,
I recently bought a system that has GPIO PCI 6503 Card installed and PA0 port is configured for an alarm unit (24 static digital IO l/ines n(on-isolated 5 V TTL/CMOS) in 8-bit ports, 2.4mA).
I am trying to use solid state relay to get an output as GREEN LED in case normal operation and RED LED in case a fault or failure reported by GPIO card but it is not working at all. I understand that GPIO card has TTL/CMOS as output and SSR relay should work with it. Am I doing something wrong.
Kindly advise.
01-28-2019 05:05 AM
You have an issue with current. The SSR wants 7.5mA of input current, but the PCI-6503 can only output 2.4mA. So you need some kind of buffer circuit to increase your current capability. There are plenty of chips out there specifically for this purpose.
01-28-2019 06:46 AM
Thank you for your quick response. Would you kindly name or advise any circuitry that can solve this problem.
Best regards
01-28-2019 09:54 AM
Just go to Digikey and do a search for Digital Buffer or Digital Transceiver. There should be lots of options for you.
