10-01-2008 08:09 AM
I am trying to design a 3 line serial communication interface. There is a clock, data, and enable line. Ideally, I would like the clock to operate at 10 MHz and the data line at half of that. I have the clock working properly with a DAQ assistant. I was able to verify the output of the 9401 using a oscilloscope. Next, I would like to send an 8-bit sequence upon command. Everything seems to be working fine in LabView. I am using a Digital Waveform Graph to monitor the data output, and the bits and frequency are correct. However, when I attach the scope to the 9401 output, the bits appear to be correct, but the frequency is around 500 Hz. How can this be? I am taking the same line that is going into the Digital Waveform Graph and feeding it into a Digital Wfm 1Chan NSamp DAQmx vi. Am I dealing with some sort of hardware limitation, or is there something else I'm not thinking of here?
Eric
10-02-2008 03:47 PM - edited 10-02-2008 03:48 PM
Hi Eric,
Thanks for posting. It looks like the code you posted is using software timing for your digital output. The 500 Hz rate that you are experiencing is the rate that your computer is processing the while loop. In order to get into the MHz range, you will need to implement hardware timing. For Digital Output, this means you need to first write the data to the buffer on your 9401, then start the task. The following code is one of the DAQmx examples showing a basic continuous digital output. You can find the example through the Example Finder under Hardware Input and Output>>DAQmx>>Digital Generation>>Cont Write Dig Port-Ext Clk.vi
This code should be a good starting point for performing continuous digital output. If you need to change the data that is being sent while the code is running, you would need to stop the task to rewrite to the buffer on your card. Thanks again for posting, let me know if you have any questions.
-John
10-07-2008 09:02 AM
10-07-2008 05:47 PM
The cDAQ-9172 does not have a dedicated digital timing engine. That's why you see it error when you select Onboard Clock. NI calls this "correlated digital" since users tend to correlate their digital data to an analog acquisition/generation.
Ok, so you can't automatically generate your own clock by using Onboard, but you can generate one from other resources on the chassis. The easiest way to do this is to use a counter to create a pulse train generation. Select one of the two internal counters for the pulse train generation (such as cDAQ1/_ctr0 where cDAQ1 is the name of your chassis). On your digital task, set the sample clock source to cDAQ1/Ctr0InternalOutput.
An alternative to using a counter is to actually create an AI/AO task and use that as your sample clock source.
The cDAQ-9172 user guide explains some of the possibilities on page 36 under the heading "DI Sample Clock Signal".
