02-14-2011 10:33 AM
I would like information about reading of the FT232RL buffer, I'm having some problems, when I read the buffer it is broken.
Like this
Ex:
’01 02 03 04 05 06 07 08’
‘09 0A 0B 0C 0D 0E 0F’
I need to read two times to get the whole frame, when the read should come like this:
’01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F’
When I have to read the buffer two times, I don’t no why, I can’t join those frames..
Seems like the buffer is not getting the entire data. In some tests i could get the entire data but takes over 500ms,
I using the Delphi XE to develop my software and I set the USB device like this:
____________________________________________________________________
procedure ConectUSB;
var
i: Integer;
begin
i := Open_USB_Device;
if (i = 0) or (i = 1 ) then
begin
Set_USB_Device_TimeOuts(20, 20);
Clr_USB_Device_RTS;
Get_USB_Device_QueueStatus;
Set_USB_Device_LatencyTimer(1);
FT_Current_Baud := 92000;
Set_USB_Device_BaudRate;
Set_USB_Device_RTS;
end;
end;
And my reading procedure is like this:
function Tfrm1.Rx3(bytes : Integer) : string; //when “bytes” receives the number of bytes that I need
var
i, cont : integer;
resp: string;
begin
frm1.vresp := '';
resp := '';
cont := 0;
while cont < bytes do
begin
cont := cont + Read_USB_Device_Buffer(bytes);
end;
for i := 0 to bytes - 1 do
begin
resp := resp + Chr(FT_In_Buffer[i]);
end;
if resp <> '' then
Result := AsciiToHex(resp);
end;
thaks for the help
02-14-2011 08:40 PM
The FT232RL is not NI Digital hardware, not any type of NI hardware. Delphi is no an NI product either. Have you tried a Delphi or FTDI forum?
02-15-2011 03:47 AM
sorry, unfortunately i've been looking out a answer to my problem
and I just make this post because i've seen many posts on this forum talking about FTDI
and i think if could someone help me with this...
so i'm sorry if the problem that I have with this FTDI do not fit with this forum
