Digital I/O
FFT analysis on FPGA
Hi ,
I want to analyse FFT Spectrum on FPGA. First of all, i would like to calculate the amplitude ( imag^2+real^2 = amplitude) of the FFT calculated values.(made up here)  then found to be the biggest value and corresponding index. How can I do this ?
regards,
Mehmet
(5,582 Views)
maybe you could use XILINX IP CORE
(5,568 Views)
Hi Mehmet,
in order to provide you with some help it would be useful to get some more details regarding your case.
1) What kind of hardware do you use? NI Hardware? CompactRIO, FlexRIO, etc. ..? Modules?
2) What kind of software do you use? LabVIEW? FPGA-module? Please also provide version information.
3) What kind of signal is your input? Is it already available in digital form or still analog?
4) Which measures to solve the problem did you take up to now? Did you use the "Auto Pwr Spectrum" function from "Signal Processing" in LabVIEW to calculate your spectrum?
Let's try to solve your problem together. 🙂
Benjamin
(5,559 Views)
Hi Mehmet,
I did a internet search on your problem and found some information that might be of interest for you.
You can find a thread discussing the same problem here: Peak Detection Algorithm for FPGA LabView
More general information on "peak detection" using LabVIEW can be found here: Peak Detection Using LabVIEW and Measurement Studio
Here you can find a VI from IPNet that could exactly solve your problem: Frame Max/Min
Let me know if this helped.
Benjamin
(5,546 Views)
Hi Benjamin ,
I use 7853R with Labview 2010 and FPGA Module. It is a analog signal.
I want to solve the problem from amplitude spectrum. I send you a screenshot from my FPGA-Programm.
regards,
Mehmet
(5,525 Views)
Why are you using this target-scopd FIFO's? The way you use them doesn't make sense.
Use the Scale by Power of 2 instead of the Quotient and Remainder function since it takes less space and only 1 tick instead of 32 ticks if you divide by a number which is a power of 2.
I would recommend you to have a look at one of the FFT examples shipped with LabVIEW.
You will find them under <labview-folder>\examples\R Series\FPGA Fundamentals\Analysis and Control\Fft
Christian
(5,517 Views)
