09-25-2008 04:51 AM
Hi ,
I have just installed the pci 6509 on a windows up machine . In the device manager everything seems fine.
Using meausurement and Automation It is recognise in the deviceand interface tree but comes back with hardware fault 50152.
cadiz1
09-26-2008
09:30 AM
- last edited on
12-20-2024
05:37 PM
by
Content Cleaner
Hi Cadiz,
Thank you for your post. Your application sounds very interesting. I have been looking into your issue and I was wondering if it would be possible if you could firstly try downloading the latest version of the DAQmx drivers called DAQmx 8.8.
If this fails to work, please can you try to insert the card into another one of the PCI slots. Alternatively, I was wondering if it would be possible to test your setup using another PCI card that you know works, so you can test to make sure the PCI slot is functioning correctly.
I hope this information helps.
Kind regards,
J POWER
09-27-2008 03:00 PM
Hi J Powers,
Thanks for your help . I tried the new driver and it has not made things better .
previously the card would show up with a green icon and a little red cross . Now it is just white . Also it no longer gets the irq number and the hex address.
Thing have become worse .
I talked to NI and they were very helpfull . I discovered that if the card has two slots it can work on 3.3 Volts and 5 Volts in the PCI slot .
So mine should work . I tried all 3 available slots . NI engineer thinks it is a dud . Only on thing left is to try in another machine .
Will do on the 18th October . Will keep you informed .
thanks
cadiz04-20-2009 02:15 PM
I am getting "Error -50152 ocurred at self-test"
when trying to install a PCI-6519 in an industrial PC (see links)
http://www.advantech.com/products/PCA-6106P3-0D2E/mod_1-2JKM6Y.aspx
http://www.advantech.com/products/PCA-6187/mod_1-2JKMU4.aspx
the NI card works fine in another PCs
can anyone help us here?
thank you
04-20-2009 02:22 PM
correction
the P/N is PCI-6518
the rest holds true
04-20-2009 02:40 PM
Hi Luis SPX ,
Thanks for looking into this . I gave the card back to the person I bought it from, the story ends there .
