Digital I/O
Error -200898 got while using 6534 to output digital signal through each line
With PCI-6534, I just want to output digital signals through each port seperately, but I got Error --200898. Here is the error message.
Error -200898 occurred at DAQmx Write (Digital 1D Wfm NChan NSamp).vi:1
Possible reason(s):
Partial use of physical lines within a physical port is not supported by this device, given the requested Sample Timing Type.
Consider specifying the entire port and tristating the lines you do not want driven
The test VIs are attached.
Message 1 of 1
(3,740 Views)
