Digital I/O
Dynamic Acq Harware Start Trigger
Hi Everyone,
I'm using a PXIe-6556 to capture digital signal. I'd  like to start capturing signal upon receiving a hardware start trigger in PFI0.
The PXIe-6556 works fine with this method when using the onboard clock but won't start capturing when I'm using an external clock via ClkIn as a source clock.
Is this a hardware limitation for PXIe-6556?
jeep
(4,852 Views)
Hello jeep,
That should work fine.  You can use an external clock and a PFI trigger.  Do you need to have your sample clock running and the session started before your external trigger event?  The PXIe-6556 does require a free running sample clock, and it needs to be operational to correctly sample triggers.
I hope that helps,
Jesse O. | National Instruments R&D
(4,850 Views)
Hi Jesse,
Before the start trigger, there is already a free running clock in ClkIn and the session has not yet started.
Jeep
(4,848 Views)
