09-02-2021 09:45 AM
09-02-2021 08:12 PM
Do you mean to reduce the sampling rate such that the edges are still intact?
If my above statement is correct - then nope, no readily available tool
But there is digital compress and uncompress - this does not change the sampling rate but only reduces the memory footprint by discarding redundant cycles
09-07-2021 04:29 PM
@santo_13 - Thank you for pointing "Compress Digital.vi" to me.
It uses its knowledge of signal transitions to remove the duplicated rows and only keeps the transition values! this is great!!
Thank you very much.
