12-09-2010 01:42 PM
Does PCI6513 supports readback of channel values?
How do I find out if the channel readback is available for certain module?
12-10-2010 04:05 PM
Hi Jane,
The 6513 does not support read back. If you want to verify what you're writing to the digital ports, I would just wire it into a digital or analog input. Some of the high speed digital IO boards( 654x,655x,656x) might support what you're looking for. What is your application?
Sean
