Assuming you are using LabVIEW, you just keep the count and the current state of the digital input in shift registers. When you detect the change, increment the count.
Another alternative is to use a counter. Read the count every so often. I don't remember if DAQmx resets the count on a read. If it does, just add to the count that is stored in a shift register.
What equipment are you using? What language?
