I finally manage to do it by creating a pulse generator on ctr0 and internally link it:
[do.error,do.taskname,do.taskh2] = calllib('nicaiu','DAQmxCreateTask','counterTask',do.counterTask); % doesnt return a pointer!! Task taskh1
do.counterTask=libpointer('uint32Ptr',do.counterTask); % thus typecast again to pointer
[do.error,do.taskname,do.taskh1] = calllib('nicaiu','DAQmxCreateTask','selectOutputTask',do.selectOutputTask); % doesnt return a pointer!! Task taskh1
do.selectOutputTask=libpointer('uint32Ptr',do.selectOutputTask); % thus typecast again to pointer
[do.error,do.lineId2,do.lineName2]=calllib('nicaiu','DAQmxCreateCOPulseChanFreq',get(do.counterTask,'Value'),'Dev1/ctr0','Counter0',do.DAQmx_Val_Hz,...
do.DAQmx_Val_Low, double(0),double(do.applicationFreq/10),double(0.5));
do.error=calllib('nicaiu','DAQmxCfgImplicitTiming',get(do.counterTask,'Value'), do.DAQmx_Val_ContSamps,do.samplesToGenerate);
[do.error,do.lineId1,do.lineName1]=calllib('nicaiu','DAQmxCreateDOChan',get(do.selectOutputTask,'Value'),'Dev1/port0/line0','Line0',do.DAQmx_Val_ChanForAllLines);
[do.error,do.source]=calllib('nicaiu','DAQmxCfgSampClkTiming',get(do.selectOutputTask,'Value'),'/Dev1/Ctr0InternalOutput',double(5),do.DAQmx_Val_Falling,do.DAQmx_Val_FiniteSamps,do.samplesToGenerate);
do.reserved=libpointer('uint32Ptr',[]);
do.write = libpointer('uint8Ptr',do.patternToGenerate);
do.writtenSample=libpointer('int32Ptr',0);
[do.error,do.write,do.writtenSample,do.reserved]=calllib('nicaiu','DAQmxWriteDigitalLines',get(do.selectOutputTask,'Value'),int32(10),uint32(0),double(10),uint32(do.DAQmx_Val_GroupByChannel),do.write,do.writtenSample,do.reserved);
do.write=libpointer('uint8Ptr',do.write);
do.writtenSample=libpointer('int32Ptr',do.writtenSample);
do.reserved=libpointer('uint32Ptr',do.reserved);
[do.error]=calllib('nicaiu','DAQmxStartTask',get(do.selectOutputTask,'Value'));
[do.error]=calllib('nicaiu','DAQmxStartTask',get(do.counterTask,'Value'));
