02-15-2006 08:00 AM
02-15-2006 08:29 AM - edited 02-15-2006 08:29 AM
Message Edited by lmd2 on 02-15-2006 09:18 AM
02-16-2006 06:11 PM
Hi lmd2,
You can make modifications to the .hws file after it was opened and saved in DWE. There is no programmatic way in which you can specify which values should load as default properties for the signal names and color. In a sense, there is no custom template that you can create which will be automatically populated every time you open your .hws files. However, once the .hws file is created, modified and saved in DWE, next time you open it the file will maintain the properties you specified. At this time, there is no access to the meta file which gives the default signal names and color.
02-17-2006 06:29 AM
