05-20-2016 11:50 AM
I am using a NI I/0 card (PCI-DIO-96) with DAQmx libraries under Linux.
I compiled and run the example WriteDigChan.c.
After i run this example, i used a multimeter to measure the voltage at each line and check if the card is working properly.
The problem is that when a line is set to logic low (0) the voltage i measure is ~4,916 Volts and when a line is set logic high (1) the voltage i measure is 0 Volts.
Shouldn't be viseversa? Or am I missing something?
05-23-2016 02:27 PM
Hi Insomnia,
This card is probably active low output by default - meaning that a low (0) will result in an active voltage. In this case since your Vcc seems to be 5V, a 0 output will result in roughly 5V being output. This also means that a logical 1 will be ouput as around 0V.
You can invert the lines using the DAQmx property function call DAQmxSetDOInvertLines.
05-24-2016 01:46 AM
I used this board years ago and the outputs are not inverted or active low.
The output should be as expected a '0' is 0V and a '1' is 5V.
Are you not measuring between a output and the +5V ??
Kees
