I'm working with a compactRIO 9002, chassis 9102 and C-series module NI-9474 with 8 digital
outputs.
I try to generate a square signal but when frecuency is less than 50 or 60 Hz, the signal become to distor
and it can change from +V to 0.
Data sheets says that "Output delay time" = 1 us, so it seems posible to work with signals of several
kHz.
I'm worry about the way to program compactRIO.
I attach the fpga VI and the compactRIO VI, they are two very simple codes.
Thanks for all.
