04-10-2011 10:42 AM
Hi sir, I am a beginning with labview. Now, I am working with Labview version 8.5 and I want to control a stepper motor in a tutotial...but the problem is I don't have enough modules to complete it...That is Data Acquisition (Digital I/O and Analog I/O...) How can I get it in my Labview version
Thank you very much
Solved! Go to Solution.
04-10-2011 11:19 AM
Click on 'Support' at the top of the page and then DAQmx.
04-10-2011 08:50 PM
Thanks sir, I have already downloaded NI-DAQmx and set up almost supports for labview but I can't find it in my front panel
Please guide me for detail
Thank you very much!
04-10-2011 09:55 PM
I don't know what you mean by finding it on your front panel. Go to the block diagram and open your function palette and then Measurement I/O>DAQmx.
04-10-2011 10:02 PM
Thanks, but I can't find it or my version misses something ....
04-10-2011 11:51 PM
That's the correct palette for the DAQmx driver. If you are looking for the traditional DAQ functions, the you tutorial is very, very, out of date but you can still install the driver if you are using an older OS such as XP. Just be aware that the functions are obsolete and you won't learn much by using them.What is the exact name of the functions and what is the date of the tutorial?
p.s. You can find the old driver by searching for 'traditional daq'.
