Digital I/O
Difference between PFI Port and DI
Hello everyone
I have a DAQ card: PXIe 6378, with which I want to implement a digital trigger.
If I use the PFI port, the trigger triggers completely synchronously if you make the same attempt more often. If I use the DI as a trigger signal, the trigger triggers sometimes earlier and sometimes later. What could be the reason for this? For information: I have set a pretrigger in both cases.
(866 Views)
General description on PFI lines - https://www.ni.com/en-us/support/documentation/supplemental/18/features-and-differences-of-ni-multif...
Please share the code for review and additional timing diagrams of what you observe and your goal.
Santhosh
Soliton Technologies
(823 Views)
