05-08-2010 12:31 AM
This particular set of test sets an output on the cdaq which stimulates a pulse response the pulse width is measured with this VI call to an input module on the Cdaq
to try over come the problem I start he timer first wait 1.5 seconds then set the output
the input has a 10second time out
so there should be plenty time to run the function
The function works but when it locks up it just sits there indefinatley
Any ideas on the issue and what the soltion is
05-08-2010 08:18 AM
Hi Rich C
Just go through all the exampal programs of DAQmax, you will find these exampal in labview help find exampal in that you vave to choose Input and Output / DAQmax exampals.
I think you have made some mistake in programming, first use create task befor starting the task.
Hope it will help you.
05-08-2010 02:59 PM
05-09-2010 11:08 AM
Hej, I have a similar problem also on a cDAQ 9178, when I do Period Measurement. The VI locks, and if I try to stop LabVIEW, it gives the message "Resetting VI: Pulse Stand-Alone.vi" (the name of my VI). I also have to turn off power to the PC. Is this the same you experience ?
The "funny" thing is, the code works OK on the old cDAQ 9178-chassis.
BR, Jan
05-09-2010 11:13 AM
05-09-2010 03:05 PM
I have Daqmx 9.02 and MAX 4.6.1.fo and using labview 2009 v9
The Cdaq 9178 is a new one we only purchased it couple months back and first time here we used them It’s populated with 5 modules at moment (2 x NI 9422 (digital in) 1x NI 9476 (32 lines digital out) 1x NI 9481 (4 channel relay card) and 1 x NI 9221 analogue input card) Jan have you had any technical help from NI yet on this? Interesting that you say previous version of the hardware did not exhibit the same issue I don’t believe the issue is just on the counters but so far haven’t proved it Not sure next step but very useful to know I am not only one experiencing the issue05-10-2010 01:18 AM
Hej, regarding SW version, I'm currently running on the newest: 2009 SP1, with DAQmx 9.10. But I have tried it on 8.2 and 2009 also with slightly older DAQmx versions, this makes no difference.
I am in contact with NI Denmark, but no answer yet. Actually, yesterday evening I tried two things, which made a change - the error before came after 2-8 restarts (never more than 8), but now I only saw it after 60 restarts. My two changes were:
- NOT wiring the error cluster to the Clear Task vi. I have a suspicion, the Clear Task vi is not working correct on 9178 when there is an error wired to it. I must say I am not sure about this, but maybe it's worth a try?
- adding DAQmx Reset Device at the end of the loop. I do this for first the modules, then the chassis.
If you have time to try these changes, it would be very interesting to hear your results.
