Digital I/O
#DO card NI - 6512 darlington driver IC A2982SLWT got damaged
Hi everyone,
While testing application with NI - 6512 DO card, Diver IC A2982SLWT for first Bank(P0) got damaged(Burned). So after that i had checked wiring but i didn't found anything wrong with the wiring.
I have attached file for understanding exact problem.
Please have a look and hope for instant reply.
(3,035 Views)
I'm awaiting your response!!
NI DO card has total 8 bank and i think each one has over-current/ Thermal shutdown protection on board, but still problem occurred. So request to NI expert, Please look into the matter. Expected better support from NI.
Prashant
(2,995 Views)
Hello, i have the same problem. Do you know what is the root cause of burned ic?
(821 Views)
what is connected to the DO? and how exactly are those powered?
Santhosh
Soliton Technologies
(812 Views)
Outputs are selenoid valves. I guess powered by NI6512. I checked all wiring there is no short or something.
(804 Views)
Do you use a freewheeling diode to avoid damage from back emf?
Santhosh
(791 Views)
there are flyback diodes on the coil of these valves. I checked them no problem. Maybe there was short somewhere, somehow happened. But it did not happen again. Thank you for your help.
(762 Views)
