03-27-2008 02:26 PM
03-28-2008 11:30 AM
Hi
You can look at the voltage levels of a digital high and low on page 2 of the data sheet. I have attached it here. The 3.3V supply does not effect the voltage at the digital output. The minimum voltage for a digital high is 2.5V and the maximum voltage for a digital low is 0.8V when you output a signal to the DIO line.
I hope this helps
Regards
03-28-2008 02:41 PM
03-31-2008 04:16 AM
Hi Wyatt
I just have a few questions to help understand the problem in order to help you:
1) What are the exact voltages that you are getting?
2) What voltage do you get when you set the port to high in you code? What voltage do you get when you set it to low?
3) Can you attach the code that you are using so I can see exactly what you are trying to do?
Regards
04-07-2008 08:26 AM
