02-09-2009 04:59 PM
Could you please help me in my problem explained below.
My problems is when I execute the VI file attached below, I get the error saying " SubVI 'DIO port config.vi': subVI is not executable". Same error for DIO port write.vi, DIO port read. vi.
I went to DIO port config.vi and executed it separtately which shows the error "Code Interface Node: Object code is not loaded".
Actually the program used to work fine and suddenly started showing this error which I could not resolve.
Below are my system specifications.
I have LV v4.0.1 running in my Windows 2000 OS. I have LAB-PC+ DAQ card to control some motors. I also have PCI-GPIB card connected to Lecroy 8901 GPIB interface for data aquisition.
I have NI-DAQ 6.6, NI-VISA for windows 95/NT installed in my system.
I attached my program file with this message.
any valueble suggestions are greatly apprecited.
Thank you.
Solved! Go to Solution.
02-10-2009 09:11 AM
02-10-2009 12:32 PM
Thank you very much Dennis..
the problem is resolved after reinstalling the drivers.
Since I had limited knowledge with NI, I was hesitant to reinstall the drivers. So, I thought I would make sure with NI forums before doing that.
Now the program doesnt show any errors.
Just for information, why do the drivers get corrupted? I just want to make sure I dont do the mistake again if I did any.
02-10-2009 02:13 PM
